Creating A Bedroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2005, 10:46 AM   #1
Creating a bedroom
I have a finished basement, but I want to make a bedroom out of half of it. The only place to make a room is on the side of the basement that has a bathroom and furnance room. My first question is do I need to keep the bedroom ventilated off of the furnance/bathroom.
Second question is the basement is carpeted, do I build the wall over the carpet, cut the carpet? I only need to build one wall and a door way. I will be using 2x4's and drywall.
Thanks for your help
insuranceguy is offline   Reply With Quote
Old 11-28-2005, 11:21 AM   #2
In my area bedroom and mech room must be seperated. no air exchange,(except thru ductwork), and no doors from bedroom to mech room. The bedroom should have an egress window and egress window well, ( big enough for a fireman with equiptment), and not too high off the floor. Be sure furnace has combustion air when your done and a work area in front of the furnace. I'm not sure exactly what your question was but maybe that helped?? HS
K2eoj is offline   Reply With Quote
Old 11-28-2005, 11:23 AM   #3
Cut the carpet. If in the future the carpet gets wet or pet stained someone will be cussing if the carpet is under the wall. It might be you cussing.HS
Old 11-28-2005, 12:01 PM   #4
Well the room already has a utility room built and the only place to put the bedroom is on that side. The utility room has a door for the washer, dryer, toilet. Do I shut that room completely off from the bedroom, and if I do can I cut a whole in the wall for ventalation?
Old 11-28-2005, 12:50 PM   #5
Not in my area but hopefully we'll get some other opinions here soon. If you were getting any carbon monoxide down drafting into the mech room and it was open to a bedroom that would not be good. There are probably a few more reasons not to be opened into a bedroom. I would be looking for a way to get outside combustion air to the furnace or you could put openings into the door that leads to the furnace and cover them with some grills. HS.
Old 11-28-2005, 01:49 PM   #6
The door into the room already has the vents in it. Do you suggest putting a regular door into the mechanical room and then possibly putting some vents or vent to the outside of the room say into the stairwell, because the stairwell is on the other side of the mechanical room.
Old 11-28-2005, 08:29 PM   #7
As long as you have combustion air being drawn from a large area inside you should be ok. Probably need to check the grill size in your doors to be sure of the proper sq.inches. I would not open a mech room to a stairway because if there was a fire in the mech room I would want the stairway protected as much as possible.HS.
Old 12-03-2005, 08:40 AM   #8
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
I would not replace the utility room door, the vents are in the door for a reason, a HVAC guy could explain, simply put, the vented door allows for air exchange for the furnace. You should check with local bldg dept before you start to make sure your remodeling complies with local codes.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 12-09-2005, 03:56 PM   #9
2nd half
You could close the vents in door, or change doors and take outside air for furnace. I'd build wall over carpet, unless you have to change carpet anyways. You can always cut it later on if it gets damaged.
Joe
jmic is offline   Reply With Quote
enlargeing or adding on to bedroom rev1953 Building & Construction 1 05-20-2007 08:13 PM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 05:03 PM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
your guestimation and or opinion on removing a bedroom shan Remodeling 2 12-09-2005 03:46 PM
Bedroom Remodel - From Scratch fizorzed Building & Construction 2 11-14-2005 10:13 AM
