Creating An Attic Entrance Inside? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-08-2009, 07:51 PM   #1
Creating an attic entrance inside?
I bought my home almost a year ago.
I have had several people (including contractors) try to figure out where the attic in my home is - and I've come to the conclusion there is no inside entrance to the attic.
I know it has one because the roof peaks and also there are two vents.
I had one guy tell me some old homes had outside entrance only attics. This house was built in 1925.
Is this possible? If so, is there a way to create an entrance to the attic inside? Is it even worth doing?
I don't think the attic is tall enough to become a 2nd story type of deal - though that would be awesome if possible. Since noone has been in it, I'm not even sure what is in there (I may not want to know LOL)!
itsamoneypit is offline   Reply With Quote
Old 05-08-2009, 08:47 PM   #2
Registered User
Rewards Points: 526
In the late '70's, I framed a few houses with outside attic accesses. Figure where you want it, check the area with an inspection hole, and put it in. 22"x30" is code minimum, with........ 30"minimum height above the ceiling (clear headroom). Do it in a hallway, easier to head the ceiling joists off.
Seal it well: http://apps1.eere.energy.gov/consume.../mytopic=11400
Be safe, G
Old 05-08-2009, 08:55 PM   #3
Could be a former owner did not use it & sealed it off
Might be a good idea to cut a small acces hole in a closet
Then you can go up & verify where you can put one
My last house didn't have 30" clearance at the peak, let alone where the pull down door was
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
creating attic storage handifoot Building & Construction 3 04-13-2008 09:15 PM
Rules for wiring inside the attic amdspitfire Electrical 4 04-09-2008 08:48 PM
Bath entrance inside kitchen area rich121 General DIY Discussions 1 12-16-2007 05:44 PM
