Crawlspace Vent In New Vinyl Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 09:19 PM   #1
Rewards Points: 162
Crawlspace vent in new vinyl siding
I'm in the process of residing my house and ran into an issue with the crawlspace. There are a series of four vent openings approximately 6"x12" ea spaced around the crawlspace of the addition. In the old aluminum siding, they simply screwed a return air grille to face of the siding and caulked around it. Not pretty, but it did the trick. I would like to do a little better with my new vinyl. Any suggestions? The big box stores don't seem to have anything that would address this situation.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-11-2010, 09:30 PM   #2
firehawkmph's Avatar
Rewards Points: 1,920
Stubby,
the big box stores only carry the bare minimum of accessory items to go with things like siding that you should be buying from a siding supply house. The siding warehouses usually stock vinyl vents that have a built in J-channel that are normally used for gable end vents. You should be able to buy small ones but probably not as small as your old ones. Google siding vents and you probably be able to buy them online if you don't have a local supplier.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-11-2010, 09:35 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
go to a siding distributer ask for a mid-america foundation master,they will probably have to order them for you
or you could use small gable vents
or it may actually be better to seal them up
Tom Struble is offline   Reply With Quote
Old 07-13-2010, 06:21 PM   #4
Registered User
Rewards Points: 526
Check the wire size and thickness if substituting other vents not intended for that purpose. Some keep critters out (1/4" hardware cloth), and some don't (screen door screening). Check with your local Building Department before you close them up.... Required open in my area. Other areas vent Radon gas, and require mechanical air changes, perimeter wall insulation, etc., if going to a closed crawlspace from a vented one.
This is why you have vents there now, the builder had to meet Code: http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
Be safe, Gary
Old 07-13-2010, 07:38 PM   #5
Rewards Points: 162
Thanks for the info. The only reason I'm looking to maintain the ventilation is because of condensation in hot humid summer weather otherwise I would close off the vents. I'll try to hit a siding supply house and order the right vent.
Old 07-13-2010, 08:28 PM   #6
the vents are probably bringing in more humidity than they are exhausting
thanks Gary,forgot about the makeup air issue
Old 07-13-2010, 09:19 PM   #7
Registered User
Rewards Points: 526
No problem.... I can honestly say, it only gets worse as you get older.....
Radon map: http://energy.cr.usgs.gov/radon/rnus.html
The bad: http://dirt-crawl-spaces.com/crawlspace-venting.html
The ugly: http://dirt-crawl-spaces.com/crawlspace-insulation.html
The good: http://www.buildingscience.com/docum...n-crawlspaces/
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tom Struble (07-13-2010)
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 12:58 AM
dryer vent through vinyl siding 7echo Remodeling 5 12-19-2008 08:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
