Crawlspace To Basement Conversion - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 10:44 PM   #1
Rewards Points: 53
Crawlspace to Basement Conversion
Has anyone out there done a crawlspace to basement conversion? I have been debating it for a while. My house is shaped like an "H". I am thinking of clearing one of the sides of the "H" out into a basement. I would need to dig about 6 foot deep by 50 foot long by 14 foot wide. Has anyone used a company for this? Would you just hire some diggers to dig as long as they stayed the recommended distance away from your supporting structure? Any advice is appreciated.
tucker0104 is offline   Reply With Quote
Old 12-28-2012, 08:28 AM   #2
Rewards Points: 13,300
What do you hope to gain by doing this?
Six ft. would not be a legal height for an occupied space. Must be at least 7'.
If you looking to gain living space it would be far safer, and most likly cheaper to just add on to what you have now above ground.
Trying to build a basement in two differant stages is a poor idea. The two footings would move at differant rates and cause some major issue.
Old 12-28-2012, 08:53 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,990
I think the poster is probably saying that they would dig down and additional 6' in this case and they net would be the height of the crawl + the 6'.
It has been done before but this is not just an excavate and you are all set project.
There are structural considerations that must be engineered in and accounted for.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mae-ling (12-28-2012)
Old 12-28-2012, 09:36 AM   #4
Rewards Points: 3,130
My brother-in-law did this under his entire house. He owns an excavating company so the digging part of the job was essentially free. Even at that, it would've been far cheaper to build an addition, but his lot wasn't big enough for that. I didn't see any of the work until it was finished, but he told me the house was essentialy uninhabitable while the job was going on.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 12-28-2012, 09:39 AM   #5
Civil Engineer
Rewards Points: 4,572
My neighbor in SC was in the process of converting a crawl space to a basement. He has been at it for several years now, hand digging. He is a mason, and is in no hurry to finish, as the property is not occupied. It is more of a hobby.
As noted, structural issues can be complicated, you definitely should consult an engineer first to discuss options for support, both temporary and permanent.
Old 12-29-2012, 12:34 AM   #6
Rewards Points: 53
Thanks for the advice for an add on but just not an option. You are correct, 3 foot crawlspace and dig out 6 foot and that makes 9 feet. I have a friend that is a structural engineer so I will have that part handled.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 01:58 PM
Basement Crawlspace Door?? floxy Carpentry 3 01-13-2008 07:35 PM
