Crack Isolation Membrane For Plaster Ceilings? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-05-2009, 05:15 AM   #1
Rewards Points: 248
crack isolation membrane for plaster ceilings?
The plaster ceiling in our second-floor bathroom is a maze of hairline cracks and crazing. The former owners had painted the ceiling with a thick sponge-textured paint to mask the problem, but now the cracks appear to have propagated through the paint.
There's no water leak problem. It looks as though someone may have stepped between the rafters in the attic long ago but caught themselves before falling all the way through the ceiling.
Are there any paint-on membrane products that could in turn be painted with a latex wall paint?
diy888 is offline   Reply With Quote
Old 02-05-2009, 05:35 AM   #2
Rewards Points: 5,336
Best thing I've come accross is fiberglass screening. Skim coat the ceiling and embed the screening into it. Put a coat or two on top and lightly sand. I use 36" wide screening and overlap about an inch.
Ron
Old 02-05-2009, 05:57 AM   #3
Remodeling Contractor
Use a fiberglass mesh system called Nu-wall. Available from http://www.spec-chem.com/nuwal/. It is a wallpaper system designed to repair cracked plaster. And you will not need to be skilled at skimming walls. It was very easy.
Old 02-05-2009, 04:20 PM   #4
Rewards Points: 248
Thanks.
I will keep the screening and skim-coat as a fall-back position, since I haven't done it before. The Nu-Wall looks like it might be a little easier in some respects, since I do know my way around a paint roller.
isolation membrane on plywood drewhart Flooring 3 11-08-2008 09:40 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
