Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-13-2012, 03:58 PM   #1
Covering slump block wall
I have slump block walls exposed on the interior of my house. I would like to cover them with sheetrock. My rooms are small so I would like to take up as little space as possible. I know I could fir out the walls and then sheetrock but is there another alternative that would take up less of the interior space? I have heard of adhering the sheetrock directly to the slump block with adhesive but I am skeptical of getting the walls level and concerns if the sheetrock could shift and end up with cracks and endless repairs. I have also heard of attaching lathe to the slump block and then applying plaster. Has anyone used either of these methods with long term success?
elmaur is offline   Reply With Quote
Old 05-13-2012, 04:52 PM   #2
You may get away with it in your area since it's so dry but it will give you no insulataion value so the outside heat will just transfure to the inside.
Old 05-13-2012, 07:46 PM   #3
Get away with what?
I am not concerned with insulation for the moment. Will address it when I look into stucco on the exterior.
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 06:27 PM
Tiered ecology block wall system installation jfwidt Landscaping & Lawn Care 1 02-24-2010 02:30 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Mortar bed removal from block wall Douger_F Building & Construction 8 04-15-2009 08:47 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
