Covering Asbestos With Hardie Board - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-25-2008, 02:05 PM   #1
covering asbestos with hardie board
I am covering over my asbestos with hardie board but am not certain what if anything I need to put in between the two.
bigrig is offline   Reply With Quote
Old 07-28-2008, 09:09 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
If I was doing the install i would strip the existing siding from the house. then install new house wrap. and new siding. I just get annoyed about the broken pieces of siding sliding down and getting in the way. I'm sure it can be done. But thats the way I work. BOB
Old 07-28-2008, 09:18 AM   #3
Registered User
Termite's Avatar
Same here. I'd recommend removing the old asbestos shingles so you can attach the hardie board right to the sheathing. I would install felt or housewrap (correctly) under the new siding.
Hardie backer board DXS General DIY Discussions 2 03-17-2009 06:40 PM
Hardie Board Textured siding instead of Stucco wesc Building & Construction 5 03-22-2008 01:43 PM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 07:00 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Hardie Board Vs.....? tattood General DIY Discussions 2 08-10-2005 10:26 PM
