#1 |
Cover wall with plywood
I would like to cover a 10' section of my garage wall from the ceiling to the floor with 3/4" plywood. This would make it easier to mount things to the wall.
Is it acceptable to cover a garage wall with wood? I am just thinking about fires. Or, can someone suggest something different. If you do agree, how do I ensure the joints stay flush? Thank you. |
#2 |
I'd suggest you ask a local official for your codes on that. I see no reason to not do what you plan; if wood cabinets are OK then a sheet of ply should be. But, that is just a guess; see an official. Could you live w/ the plywood covered w/ sheet rock and perhaps cut a tad undersize so the sheet rock would cover it and you could mud the edges? If you will be welding or have open flames, I'd sure sheet rock over the ply, code or not.
#3 | |
Cover wall with plywoodQuote:
#4 |
Cover wall with plywood |
#5 |
Why not just use 1/4 peg board or slat board.
#6 | |
AHH, SPANS!!!
#7 | |
Why don't you check with the higher-authority: your wife??? |
#8 |
#9 |
#10 |
I don't think peg board will be strong enough. I am not sure I know what slat board is.
The point of the exercise is hanging garden tools and making a rack to hold the small refrigerator, as well as a pull point for the drop light and air hose. If I have plywood up, presuming it is appropriately affixed to the studs I could just put all my requirements where I want. Don't get me wrong, there will be peg board above the work bench |
#11 |
journeyman carpenter
as long as you have 5/8 drywall thats taped behind the plywood your fine.. just be sure to use 2 1/2" screws with gromets to fasten it to the studs so it holds
#12 |
#13 |
theres no difference in exterior to interior screws other than the deck ones are coatd.. the gromets will help with holding power or use washer head screws which basically do the same thing as gromets
#14 | |
I could always use ring shank nails, but then I would hate myself later if I ever needed to take it down |
#15 |
oh.. definitely dont use drywall screws.. drywall screws are for one thing hanging drywall not for hanging things off of drywall. they dont have any shear strength you have to use wood screws
| Display Modes | |
| Make waterproof barrier between plywood wall and concrete foundation. | gbradley | Building & Construction | 1 | 10-24-2010 02:48 PM |
| distance from plywood shear wall to foundation | pttcc | Building & Construction | 3 | 08-24-2010 12:18 AM |
| Advice on retaining wall replacement (pics inside) | eastie | Building & Construction | 0 | 04-05-2010 11:32 AM |
| Washer agitator/spinner turns one way, but not the other | IckesTheSane | Appliances | 5 | 01-10-2009 03:53 AM |
