Countertops, Crooked Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 12:28 PM   #1
countertops, crooked walls
help PLEASE, need help with what angle should be if when at 45 degree angle counter top is 1.5 inches away from wall? what angle do I cut at to make the difference
dailacres5 is offline   Reply With Quote
Old 07-25-2010, 01:27 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
1 1/2" away from what wall?
your question doesn't make a lot of sense as it is written. I can see where a wrong end angle could cause the problem or a too long countertop could cause the same thing. You don't say which wall and where on that wall.
if you can post a pic, it would help a lot.
Old 07-25-2010, 01:37 PM   #3
countertop HELP PLEASE
countertop is ok on one side of L-wall, other wall is not square. When I match up countertop at 90 degree angle it comes away from wall by an inch and a half. wondering what angle I need to cut this corner to to bring countertop back to wall
Old 07-25-2010, 01:59 PM   #4
DIY staff
Rewards Points: 7,174
Fold a large sheet of paper to fit the corner----then fold the paper in half---that is the miter angle.
---Mike---
Old 07-25-2010, 02:36 PM   #5
nap
You talking to me?
nap's Avatar
If you have room to slide the top so the side you do not have to cut can be put against the wall, you simply do that and slide the top until it touches the other wall. Then you scribe your cut onto the counter top.
just be sure the top is long enough to be able to cut this off and still cover the full length of the counter base.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 01:54 PM
Installing Plumbing in 2Ē Wide Walls? Robert1_1 Plumbing 5 09-16-2009 09:43 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 10:37 AM
