Countertop That Is To Be Replaced By Granite - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 09:28 AM   #1
countertop that is to be replaced by granite
How do I remove a countertop that has a 4 inch splash guard? The countertop and splashguard are one piece it appears or two and the laminate countertop is curved and affixed. The countertop must be affixed with an adhesive and just sits on the cupboards because I cannot find any screws that hold it. Thanks in advance!!
bjacobs50 is offline   Reply With Quote
Old 09-25-2011, 10:14 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Carefully pry it up and verify what you suspect.
Old 09-27-2011, 03:43 PM   #3
Rewards Points: 5,336
Odd to have just adhesive as the laminate counters seemed to be a little curved and the screws brought them tight to the cabinets. There should be squeeze out inside the cabinets if silicone or adhesive were used.
If they're glued, it will be a more tedious project to remove them.
I'd cut along the backsplash first and remove that. Them separate the top fron the cabinets with a rigid 1" taping knife. Drive it between the cabinets and then along the top, separating the two units.
Once the front and sides are separated, you can lift the top with minimal damage to the wall because the backsplash is removed.
You might find that the cabinets are not level enough for a granite top and some adjustment will be needed.
Ron
B. Franklin 1759
2cm Granite Countertop Installation ambersinha Kitchen & Bath Remodeling 4 09-16-2011 12:36 PM
Creative uses for countertop granite scraps Part 2!! Rhizzlebop General DIY Discussions 8 03-31-2011 09:06 AM
Granite tile for countertop speedster1 Remodeling 18 12-16-2009 07:16 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Creative uses for countertop granite scraps 1 Rhizzlebop General DIY Discussions 10 06-01-2009 07:18 AM
