Could I Put Doors On This Jetted Tub? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 10:41 PM   #1
Could I put doors on this jetted tub?
** See Picture attached**
I'm assuming doors would mount to the edge of the deck mount in front of the tub, but I would need to put in some type of solid surface of 2.5-3' to extend along the edge of the tub from the wall. Do they make glass doors for this with a sturdy corner so I could mount the front doors? Would I be able to drill into that tile? If so, is there a place online to purchase such a thing? It's marble.
Sorry wish I had a better pic, this is a house im interested in buying and this is the only picture i have
bluscreened is offline   Reply With Quote
Old 08-24-2009, 04:20 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Very much not an expert here but I'll put in my two cents since no one else has responded yet.
I assume the reason you want doors is to use this as a shower?
First, you want all the water to drain to the tub and....well... go down the drain, not pool anywhere else. If you mount any type of shower door on the edge of the deck you will have a low area between the doors and the tub which will collect water. Even if you install the doors against the tub there will still be a dip there.
At best you will have to dry this out after every use to keep mold from developing.
At worst water will leak between the tub and deck and cause water damage.
I'm not sure what you want to do is feasible, but someone else more experienced here may have a better idea. Perhaps installing it on the edge of the tub, but then you have the corners to deal with.
I'm also slightly confused by the pic. Is it currently used as a shower? The curtain makes me think so, but the little deck area with the bottles on it doesn't seem like a good idea for the above reasons (it looks lower than the tub edge) .
Old 08-24-2009, 04:37 PM   #3
indeed the area where the bottles are is below the tub rim. Maybe this does cause the current owner a problem. i should have taken more pictures of the place.
THANKS FOR YOUR HELP BTW!!!!
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 11:26 PM
UGH! A lesson for new Pre-Hung Doors javan General DIY Discussions 6 08-08-2008 08:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
