Could I Cause Myself Problems? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 11:33 AM   #1
Rewards Points: 97
Could i cause myself problems?
i have a room i am renovating. Three walls are exterior walls. I have stripped the walls inside the house to the studs and found no rot. The exterior is cedar siding nailed over felt paper directly on to the studs. No sheathing or spacers of any kind. The interior used to be cedar siding with no vapor barrier. In between the walls they had stuffed in batt insulation (2x6 kind even though it is a 2x4 wall). Again, there was no rot with this setup. I want to board the interior with drywall. I will replace the fiberglass batt with roxul but am worried that i might end up encouraging rot or mold to occur. Any thoughts? This wall is above grade and i am in Vancouver BC.
bcbud3 is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 08:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 08:09 AM
steam heat problems alanliz HVAC 8 01-18-2009 08:10 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
