Correct Way To Install Aluminum Window Casing? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 01:42 PM   #1
Correct way to install aluminum window casing?
We had some windows replaced last week and the installer installed aluminum casing to the exterior using nails. I didn't think that was the correct way to install casing. For one it does not have a smooth look to the casing and secondly you're putting holes in the aluminum, making it possible for water to work its way to the unpainted wood behind the aluminum. Before speaking with the installer about my concerns I want to confirm if this is an acceptable way to install casing.
I appreciate your advice.
Thanks, Dave
DavesHammer is offline   Reply With Quote
Old 01-14-2008, 01:55 PM   #2
Oldguy
Rehabber's Avatar
That's the way it is normaly installed
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-14-2008, 04:06 PM   #3
We had some Marvin windows installed about 6 years ago and the capping contains no nails. We did find out some friends down the street, who recently replaced all of their windows, do have nails in their capping. However their nails are located near the corners of the capping and not in the center. What's the more common location for the nails?
Thanks, Dave
Old 01-14-2008, 04:36 PM   #4
Oldguy
Rehabber's Avatar
Every window manufacturer will have their own installation instructions. I follow those instructions, but I know others who use there own preferances with complete long term success
Old 01-14-2008, 04:57 PM   #5
Can you post a photo?
Trim nails are usually used that are the same color as the trim and have a smaller head.
redline is offline   Reply With Quote
Old 01-15-2008, 05:51 PM   #6
Rewards Points: 5,336
Dave, post a picture or two so we see what you mean.
Ron
Old 01-16-2008, 12:03 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Much of the time it is "possible" to install aluminum capping without using nails by getting a compression fit coupled with caulk, however every house is different and sometimes nails are needed. To be honest though, nails are almost always used because it is more practical, as well as an extra security measure that your trim isn't ripped off in a windstorm. Water/air penetration is not a factor unless the nails are installed in a poor location such as through the drip flashing on the top of the window. As far as what location is appropriate, face nailing (on the front surface) should be avoided as much as possible for aesthetic reasons, but again, sometimes they are neccessary. The main thing that would be unacceptable would be if there are big dents/divits in the aluminum where the nails are located. This can be avoided and would indicate hack work.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-16-2008, 01:39 PM   #8
I spoke with the project manager and he is going to review the work and most likely have them reinstall the capping.
Thanks, Dave
Cut and install new window mustanger Building & Construction 4 12-01-2007 12:18 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
