-   -   correct order to finish basement (http://www.diychatroom.com/f15/correct-order-finish-basement-136422/)
diy001 03-08-2012 04:57 PM
I will use poly + foam + plywood + engineered laminate/wood floor to do basement floor. And I will use foam + wood frame + fibreglass + drywall to do the basement wall.
I plan to follow this order to install them:
1. put poly on the floor and all the way up 1 foot on the wall, seal every where when possible to make it as air tight as possible;
2. put wall foam (2" XPS) and glue them on the concrete wall, seal every where;
3. put floor foam (1" XPS) and seal every where;
now we have an envelop of rigid foam.
4. start wall frame, nail down with concrete and nail up with joists;
5. put plywood, just floating on top of the foam;
6. wiring and plumbing;
7. put fibreglass;
8. put drywall;
9. put engineered laminate/wood floor;
Some experts suggested put plywood before framing. So the frame is on top of the plywood.
What's your suggestion about my installation sequence?
oh'mike 03-08-2012 08:30 PM
Dinner is ready so this must be short---your method of building a floor is very unusual--that's likely why no one has answered you----it sounds like a mildew sandwich--
Why are you adding foam and plywood to a concrete floor?
Crackers 03-09-2012 01:04 PM
If the foundation leaks and you have to lift the floor; really hard if the floor goes under the wall. I prefer to leave them independent.
Yes, wood on concrete floor is difficult on the wood. Raised floor is nicer.
