Corner Shower - Tile Dimension Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 01:53 AM   #1
Rewards Points: 892
Corner shower - tile dimension question
I'm installing a 42" x 42" neo angle shower pan. Will tile the walls.
Do you think my tile should be 42" from corner of shower, or should I go further beyond the 42" marker? and why?
I think 42" would be cleaner since the pan is that width, but I saw a few pics online that show the tile going about 4 inches beyond that. Thoughts?
Daugela is offline   Reply With Quote
Old 06-22-2013, 06:25 AM   #2
DIY staff
Rewards Points: 7,174
How far beyond the door or edge of the pan you go is up to you---
I prefer to extend the tile 3 to 4 inches past the shower wall, but that is just a personal preference---
woodworkbykirk (06-22-2013)
Old 06-22-2013, 07:03 AM   #3
MarginallyQualified
Rewards Points: 2,464
Well beyond. Cover the area behind around the toilet (on one side) and the wall behind the sink (on other side) ... but at least a couple of inches past the enclosure frame and down to the floor.
Old 06-22-2013, 09:31 AM   #4
Rewards Points: 892
Yeah, I thought I should extend it alittle. I'm not installing a glass door but rather a rounded shower curtain.
Also, the Kohler instructions are really vague. Some say to drill through the base to the studs but others say DONT. The others say to use fender washers to hold the base to the stud. Ideas?
Tile shower leaking gregsenne Plumbing 9 10-02-2012 10:00 PM
Tile Redi Shower pan hole question daman60 Kitchen & Bath Remodeling 2 10-01-2012 05:24 PM
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 06:09 AM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
