Corian Vanity Top Installation - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-23-2008, 07:07 AM   #1
Hello,
I'm remodeling my bathroom and have come to a part that I just don't know how to do and that's installing my Corian vanity top to the cabinets and how to attach the sinks to the Corian top. I have the metal brackets for the sink but wasn't sure if I should just screw in the screws and or should I use some sort of caulk too?? As for attaching the top to the cabinets should I just glue it on? Add screws...any help with this would be great. Thanks
MrknDrk is offline   Reply With Quote
Old 04-23-2008, 09:17 AM   #2
RippySkippy's Avatar
Originally Posted by MrknDrk View Post
...As for attaching the top to the cabinets should I just glue it on?
100% silicone caulk will be more than adequate for everything you're wanting to do.
Attach the sink, and caulk the seam between the sink and top. Same for rim or under mount. Your goal is to keep water from getting under the rim and into the vanity.
First, make sure the vanity is level and square and the top doesn't rock when it's set on top. Fix any imperfection before adding the caulk. Around the perimeter of the vanity carcass, run several 2 to 3" long strings of caulk, set the top on and don't budge it until it sets,
RippySkippy is offline   Reply With Quote
Old 04-23-2008, 09:24 AM   #3
RippySkippy
Thanks much..so I shouldn't use the mounting brackets and screws I have for the sink attachment...just use the silicone??
Old 04-23-2008, 10:25 AM   #4
No, use the screws that came with the sink...the silicone is after you physically fasten the sink to the counter...
Old 04-23-2008, 10:33 AM   #5
RippySkippy
Ok..thanks again. I'm assuming that the backsplash is installed the same, using the silicone and then caulked?
Bathroom vanity rough in diyer4162 Carpentry 13 11-09-2007 05:36 PM
replacing sink in corian vanity top jaybee General DIY Discussions 2 09-01-2007 02:08 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
