Converting Window To A Door Help! - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-12-2008, 11:57 AM   #1
Converting Window to a door Help!
Hello all. I am building a balcony off the master bed room. I have plans that have been approved by the building dept. I would like to convert an existing window into a door to the outside balcony. The building dept says I need a permit only if I have to make the width larger because it involves a new header ect. So I am wondering id there are doors that are narrow enough to fit?the width of the rough opening is about 29 inches.
Any insight would be greatly appreciated!
Keith
fisherk is offline   Reply With Quote
Old 07-12-2008, 01:55 PM   #2
Registered User
Termite's Avatar
Doors are readily available to 24" widths. An exterior door that small might be a challenge. Call local millwork suppliers and I bet you'll find something.
Old 07-12-2008, 06:32 PM   #3
Thanx for the info!
Tags
window to door
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Shower in Window jchri66 Remodeling 1 05-27-2008 12:50 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 10:06 PM
