Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 08-01-2012, 10:49 PM   #1
Post
Converting window
I have very little experience with carpentry and any DIY tasks but I'm wanting to try this on my own. I recently bought a 50 year old house. In one of the rooms a bathroom was added to an outside wall. They didn't remove the window that was already there so now you can see the drywall through the glass. I was hoping to remove the window and possibly convert it into a built-in wall book case.
Again, I have very little experience and everything I've been finding is just how to replace the window with another, but I was wondering what the best approach was if I just wanted to remove it entirely. Anything I should be aware of or is it just basically remove the casing and then the nails securing the window?
the_only_one is offline   Reply With Quote
Old 08-02-2012, 11:40 AM   #2
Converting window
There should never be a storage area built into an outside wall.
The window needs to come out, A 2 X 4 added if 16 or 24" wide insulation will not work, sheathing and some form of house wrap added over it then repair the siding.
What type siding is it?
Old 08-02-2012, 02:40 PM   #3
Converting window
It's a brick house. The bathroom was already added on before I even moved it. You can see drywall pressed up flat against the other side of the window.
Old 08-02-2012, 03:24 PM   #4
Converting window
I think the OP has an outside wall that after remodelling became an inside wall with a window in it that does not go all the way through, but is covered by drywall on the previous exterior surface.
Do you know any more about the wall construction? Is just brick, or brick and block, or wood framed with full size brick facade, or brick with interior wood wall?
Once you get the window out (easier said then done) you'll have a nice should be structurally sound opening to build a bookcase. Keep life simple and keep the opening the same size.
goosebarry is offline   Reply With Quote
The Following User Says Thank You to goosebarry For This Useful Post:
DangerMouse (08-02-2012)
Old 08-02-2012, 03:42 PM   #5
GBrackins's Avatar
Converting window
a photo or two would be nice
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 08-02-2012, 03:50 PM   #6
Converting window
Wood framed with brick facade. I know it had a exterior storm window at one point but that was removed when they added on. Now all that's left is the wood window.
Old 08-02-2012, 09:29 PM   #7
AHH, SPANS!!!
Converting window
it seems the obvious is to take out window, re-frame, insulate and sheath and then put brick over the hole. Done
hand drive is offline   Reply With Quote
converting wood to steel for window header Dan S Building & Construction 7 05-22-2010 02:44 PM
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
