-   -   Converting window (http://www.diychatroom.com/f15/converting-window-152274/)
the_only_one 08-01-2012 09:49 PM
Converting window
I have very little experience with carpentry and any DIY tasks but I'm wanting to try this on my own. I recently bought a 50 year old house. In one of the rooms a bathroom was added to an outside wall. They didn't remove the window that was already there so now you can see the drywall through the glass. I was hoping to remove the window and possibly convert it into a built-in wall book case.
Again, I have very little experience and everything I've been finding is just how to replace the window with another, but I was wondering what the best approach was if I just wanted to remove it entirely. Anything I should be aware of or is it just basically remove the casing and then the nails securing the window?
joecaption 08-02-2012 10:40 AM
There should never be a storage area built into an outside wall.
The window needs to come out, A 2 X 4 added if 16 or 24" wide insulation will not work, sheathing and some form of house wrap added over it then repair the siding.
What type siding is it?
the_only_one 08-02-2012 01:40 PM
It's a brick house. The bathroom was already added on before I even moved it. You can see drywall pressed up flat against the other side of the window.
goosebarry 08-02-2012 02:24 PM
I think the OP has an outside wall that after remodelling became an inside wall with a window in it that does not go all the way through, but is covered by drywall on the previous exterior surface.
Do you know any more about the wall construction? Is just brick, or brick and block, or wood framed with full size brick facade, or brick with interior wood wall?
Once you get the window out (easier said then done) you'll have a nice should be structurally sound opening to build a bookcase. Keep life simple and keep the opening the same size.
GBrackins 08-02-2012 02:42 PM
a photo or two would be nice
the_only_one 08-02-2012 02:50 PM
Wood framed with brick facade. I know it had a exterior storm window at one point but that was removed when they added on. Now all that's left is the wood window.
hand drive 08-02-2012 08:29 PM
it seems the obvious is to take out window, re-frame, insulate and sheath and then put brick over the hole. Done
