Convert Two Door Garage To A One Door Garage - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-30-2006, 11:24 AM   #1
Rewards Points: 150
Convert two door garage to a one door garage
How hard is it and how much money should I expect to pay in order to turn a house with a two car garage with two doors into a two car garage with one big door?
ConstantChange is offline   Reply With Quote
Old 05-30-2006, 02:47 PM   #2
General Contractor
joasis's Avatar
First thing, before you think any further about doing it, is to know how the proposed change in doors will work once you remove the center post between the doors. Is this in a gabled endwall with a truss rafter above it? Sidewall? You may have a structural issue when you attempt to remove the center post, as well as putting in a full header above the wider door opening.
joasis is offline   Reply With Quote
Old 05-30-2006, 04:00 PM   #3
Rewards Points: 150
I'm actually just looking to buy a house and want a two car garage with a single door. I've seen several on my buyers report that are decent houses but have the two door garage. So far I've decided to not even look at the house unless it has a single door garage, but if it's something that could be coverted without spending a great deal of money, I might consider it.
Old 05-30-2006, 06:37 PM   #4
General Contractor
joasis's Avatar
That being the case, depending on where you are, the prices could be from reasonable...$3500 to the sky. The problem is basic: Most single doors, side by side, are 8 or 9 feet wide. Door headers usually only span the doors, and not across the center post. You would have no way of knowing how it was built unless the garage walls were not rocked. Like I said, it is a structural thing, and could get really pricey.
Old 05-31-2006, 09:31 AM   #5
Rewards Points: 150
Sounds like something I'll try to avoid. Thanks joasis.
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Convert an Outlet into a Switch? Geo747 Electrical 3 07-08-2007 10:23 AM
convert bulk carpet to finish carpet possible? KUIPORNG Flooring 7 05-16-2007 10:54 PM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 11:17 AM
Convert 277v to 120v tricks? Fux39 Electrical 16 11-26-2006 08:17 PM
