Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-23-2007, 04:12 AM   #1
Default Considering widening interior doorway - How difficult?
Hello everyone,
I am considering widening the doorway to my office in my home. My wife and I are purchasing new furniture and I would like to put in an executive style desk that is 30" high.
Unfortunately the door width is 29.5". I really don't know why they would have built the doorway this small since every other door way in the home is more then 30".
Having a width smaller then 30" is seriously limiting our options for office furniture and if this door could be easily widened I would like to do it.
Hopefully someone here has done something like this and could shed some light on how difficult a task this may be.
Thanks,
Dave
davewolfs is offline   Reply With Quote
Old 05-23-2007, 08:30 AM   #2
I'd just remove the trim, or even the entire jambs to get your furniture in, and then put it back on. That'll gain you 3 inches or so.
NateHanson is offline   Reply With Quote
Old 05-23-2007, 09:24 AM   #3
Default How hard is that to do?
How hard is that to do? Isn't a lot of this stuff glued down? If so, I am assuming I am going to have to rip everything out. Will I need a crow bar to remove the Jam?
Is there a clean way to remove this?
Thanks for the reply.
Dave
Old 05-23-2007, 09:34 AM   #4
They're usually attached using nails--not glue. You'll want to gently remove the casing using a pry bar or wide spackling knife. From there, you will be able to see how the rest is attached. You'll see how much space there is taken up using shims. You should be able to slip a reciprocating saw blade between the studs and the door frame. Cut the nails.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 05-23-2007, 09:49 AM   #5
Looking at the casing, there is a ton of paint over hit. It is attached extremely tight, I tried fitting a small flat tool between the casing and the wall but they are so close together that I feel if I push the tool in too hard I am going to start taking out chunks of dry wall. Is there a specific spot in the casing where I should attempt to remove it?
Old 05-23-2007, 09:53 AM   #6
Take a utility blade and cut the paint to break the seal. You can try slipping the spackling knife through from the door side as well.
Old 05-23-2007, 10:50 AM   #7
You're not going to be able to do this without needing to do a little touch-up work when it's all done. Patching some dings in the drywall, and filling some nicks in the casing (as well as the new nailholes you'll be creating when you reattach) is not a big deal. You were considering doing some major construction to widen this door a few hours ago, so don't worry too much about an hour of cleanup work that'll be required after reattaching the jambs and casings.
I think you'll need a flat bar or a trim bar (small flat bar) to get the casing off. You might get it started with a stiff 2" putty knife, and then you can get the bar in there with less damage. Start at an end of a board, not in the middle, then work your way down to the other side.
Old 05-23-2007, 10:52 AM   #8
If all you need to do is get a 30" tall desk through a 29.5" wide door, I'd just try to maneuver the desk in without removing the door frame first.
Depending on the shape of the legs/base you can get a table through a doorway that is much taller and wider than the actual opening.
Old 05-23-2007, 11:08 AM   #9
Thanks again for the reply. I truly wish it were that easy. But most of the desk I am looking at are this style:
http://www.sligh.com/product_detail.php?product_id=72
One that may fit, but again I am doubtful is:
http://www.sligh.com/product_detail.php?product_id=76
Old 05-23-2007, 11:21 AM   #10
I think you could definitely get that second one through if all you need is 1/2" extra.
The first style definitely doesn't give you any wiggle-room though.
Old 05-23-2007, 12:14 PM   #11
Second for sure if I go vertical with the desk and just get the legs around the door.
I just spoke with the manufacturer and the tops come off to make these desks 29". So looks like a false alarm
BTW, thank you all for the responses. Seems like you have a great forum going on here.
I am considering installing a pocket door so I might give y'all a holler in the weeks to come.
Thanks again,
Dave
Old 05-23-2007, 03:26 PM   #12
They're all fixer-uppers
J187's Avatar
Are we talking about the door width with your door attached or have you taken it off the hinges? If the door itself is still attached, then popping out the hinge pins and putting the door aside should net you enough room.
EDIT
I just read that you solved it, good to hear.
TRY IT, IT'S SO MUCH FUN!
J187 is offline   Reply With Quote
More On This Topic
How Much Drywall Do I Need?
How Much Drywall Do I Need? by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about calculating materials for drywall. Each sheet of drywall is 4 feet, so I am going to go ahead and measure the length of my wall. The measurement of my wall is 23... Read More »
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality assurance walk through around this house. What you are going to be looking at stuff in your home here is that a lot of this stuff is... Read More »
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
Hi! My name is Connie Hale and thanks for joining me here at expertvillage.com. Today we are going over some beginning ballet moves. Right now we are going on to rond de jambe. Rond de jambe is starting in fifth position. Hand is resting on your support... Read More »
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Now we're going to talk a little bit about spackling on a door jamb. Now, earlier we talked about spackling walls. Now interior or exterior walls... Read More »
how difficult is it to replace windows kenny357 Building & Construction 6 05-30-2007 11:35 PM
Widening a doorway in a load bearing wall EFEmm Building & Construction 3 03-23-2007 09:17 AM
Difficult Airlock Problem? beachbum Plumbing 4 01-15-2007 10:16 AM
Difficult to carry/install water heater in Attic? sz8 Plumbing 1 01-07-2007 10:49 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
