Concrete Steps - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 12:04 PM   #1
Concrete steps
What is the best way to take out concrete steps that are solid? Jackhammer? Manpower?
kenny2501 is offline   Reply With Quote
Old 06-22-2010, 10:12 PM   #2
Concrete & Masonry
Rewards Points: 548
Best? I'd take a hydraulic hammer on a piece of equipment like a skid steer or mini-excavator before your other 2 options. If you have a basemnt behind these steps, I'd consider putting some temp. bracing against the walls as well.
jomama45 is offline   Reply With Quote
Old 06-23-2010, 09:21 AM   #3
Depends upon if it is solid concrete, built with blocks etc
I've used a 10 lb sledge to break it up
Old 06-23-2010, 10:18 AM   #4
Thanks, that sounds like the most economical way
Old 06-24-2010, 09:31 PM   #5
Rewards Points: 1,910
Ornery teenager with sledge hammer is the best and most economical way. I've done a small one with a sledge. Once it got going it wasn't too bad. But jomama's solution is a lot easier.
Old 06-29-2010, 01:26 PM   #6
Try a material called the cracker www.atc.ws
fixing concrete steps with slate jarby Building & Construction 3 06-04-2010 08:20 AM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
steps up from concrete patio annrose Landscaping & Lawn Care 2 09-10-2009 07:07 PM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-22-2008 11:22 PM
Concrete steps Shadowchase Building & Construction 5 07-04-2008 06:01 PM
