Concrete Shower Base Demo - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 01:22 PM   #1
Concrete shower base demo
Hi everyone...new to forum so my apologies if this topic should appear elsewhere.
2nd floor master ensuite shower stall was leaking from beneath so I took this opportunity to redo our shower. I have a gazillion questions re this project but will stick with the here and now! I've removed everything but the concrete and mortar slab that resides beneath the tile and above the plastic shower pan/liner. Problem is a hammer and chisel is not getting the job done-not this decade anyways. I see that small jack hammers are an option but I'm worried about being on second floor (above our kitchen)....how 'violent' would this tool be?
Btw, this is all on a plywood subfloor.
Thanks in advance!
Snaik69 is offline   Reply With Quote
Old 03-17-2013, 01:36 PM   #2
Rewards Points: 13,968
http://www.amazon.com/Bosch-11255VSR.../dp/B000BB79Q6
One like this will work great.
It's held almost vertical when removing the old morter and will do no harm below unless your have some other issues.
Old 03-17-2013, 02:15 PM   #3
Thank you. I will try to rent one at HD. I keep picturing Wiley Coyote jack hammering through rock and plummeting to his death
This tool seems a bit more tame than a jackhammer....
Old 03-17-2013, 07:22 PM   #4
Rewards Points: 236
did you try prying it up in one piece ?
Fix'n it is offline   Reply With Quote
Old 03-17-2013, 08:01 PM   #5
No I have not....worth a shot but would need to create some space to get pry bar leveraged properly-cant really get under it.
Old 03-18-2013, 04:43 PM   #6
Thanks joecaption, this tool did te job. Like cutting through butter!
The Following 2 Users Say Thank You to Snaik69 For This Useful Post:
oh'mike (03-18-2013), Windows on Wash (03-19-2013)
Using Concrete as Paver Base? Boiler98 Landscaping & Lawn Care 4 07-27-2012 10:09 AM
fiberglass shower base drain help busa4 Plumbing 8 05-22-2012 01:09 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Installing a new shower base frgwtchr Plumbing 2 08-17-2009 06:30 AM
landscaping backyard with Pavers - needs concrete base? sundar Landscaping & Lawn Care 7 10-09-2008 07:28 PM
