Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-18-2013, 11:04 AM   #1
Concrete, Foam Board then Drywall
I'm going to begin work on new stairs to my basement. One side of the stairs butts up against the concrete foundation. As it stands now, the stairs are very narrow. Would it be OK to glue 1" foam board to the concrete wall, then glue and tapcon drywall through foam board into concrete, and then install the stringer up against that?
Any other ideas?
Thanks.
benleef is offline   Reply With Quote
Old 01-18-2013, 12:28 PM   #2
Stringer needs to be held away from the wall to be able to fit the skirt board.
Old 01-18-2013, 12:54 PM   #3
Thanks didn't think about that! But as far as plan with foam and drywall--that's an OK method?
Old 01-18-2013, 02:43 PM   #4
Using furring strips or fully framing on the other side of the foam is the standard method. If you need that extra 3/4"really bad its probably ok. Not sure if space for airflow behind the drywall is needed. Depends on how you have the vapor barrier setup.
michaelcherr is offline   Reply With Quote
Old 01-18-2013, 06:36 PM   #5
Although not ideal, many stairs are installed near the concrete and we have to improvise. I use as much styrofoam as I can (1-2") glued on then glue and tapcon (concrete) screws. Make sure the Glue (adhesive is ok for the concrete to Styrofoam connection, then for the Styrofoam to drywall.
mae-ling is offline   Reply With Quote
Cold storage: Drywall over exterior poured concrete walls? TomU Building & Construction 3 11-19-2012 01:31 PM
foam and foam board flammability bubbler Insulation 18 10-22-2011 02:18 AM
Best adheasive for foam board to concrete BlueBSH Building & Construction 1 08-05-2011 04:06 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
Foam Board on exterior of above grade house Sheldon General Discussion 6 12-08-2009 05:05 PM
