Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-23-2006, 05:19 PM   #1
Concrete dust in Basement
I have a considerable amount of concrete dust in my basement. I would like to finish the floor with Vinyl tile. Does anyone know if I need to seal the floor prior to laying the tile. Or will the tile adhesive act as a sealer as well?
bobpena is offline   Reply With Quote
Old 11-07-2006, 01:13 PM   #2
You will need to get up that dust before laying any sealer on it first. Use a shop vac if you have to. Wear a mask.
TOMatLEVETEC is offline   Reply With Quote
Old 11-20-2006, 03:08 PM   #3
After I clean the floor can I used the tile adhesive as a sealer? Or do I have to seal the concrete and then use tile adhesive. I was trying to eliminate a step. Thanks in advance for your help.
Old 11-20-2006, 03:20 PM   #4
Tileguy
Bud Cline's Avatar
What is the moisture content of the concrete floor?
Say What!!!
Old 11-26-2006, 01:43 PM   #5
The concrete floor is very dry.
Old 11-26-2006, 02:34 PM   #6
Tileguy
Bud Cline's Avatar
Go for it. No sealer required.
Old 11-27-2006, 05:15 PM   #7
Thanks. Now i no longer have a reason to procrastinate.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Concrete Problem in Basement!! pilotandy72 Building & Construction 3 07-31-2007 04:19 PM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 08:42 AM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 03:14 PM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
