Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-07-2008, 09:55 AM   #1
Concrete cure
Does anyone generally know how long concrete takes to cure? I got concrete installed in the crawl space 4 days ago and the humidity down there is still at 87%. I have the 4 vents open with 3 fans circulating the air. I know teh humidity will go down eventually, but how long should I keep the fans going for.
Tim
timchi29 is offline   Reply With Quote
Old 11-07-2008, 02:01 PM   #2
gravity always wins
Concrete cure
Are you sure your meter is accurate? Concrete will reach it's full rated strength in 28 days, but most of the moisture should be out of it within the first few days. At any rate, measure the moisture at the ceiling level. Anything over 65% with temps of 40-100 degrees is prime mold growing environment.
Old 11-07-2008, 02:51 PM   #3
joed's Avatar
Concrete cure
Concrete cure and concrete dry are different things. Concrete cures best when wet. The first 7 days are most critical and then after 28 days it fully cured.
Put a dehumidifier on.
Old 11-07-2008, 03:38 PM   #4
Concrete cure
I put it outside and it matched what the weather folks are saying so I put is back inside, at the ceiling at is says 84% at 66 degrees.
Old 11-07-2008, 03:45 PM   #5
Concrete cure
I might want to add that it i3 75% humidity outside and damp and I have the vents open to circulate air. Does that make more sense?
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 12:43 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
