Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-20-2005, 05:44 PM   #1
Construction Junkie
Which comes first-floor or vanity?
After laying new subfloor, do I put in the floor tile then install the vanity, or the other way around? It seems logical to put in vanity then tile up to it, but I've been told different.
sharisavage is offline   Reply With Quote
Old 06-20-2005, 07:42 PM   #2
Remodeler
MinConst's Avatar
I'd say put the tile down then the vanity. If you ever change the vanity you have the floor under it.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 06-21-2005, 12:33 AM   #3
Super Moderator
Floorwizard's Avatar
what will the vanity be bolted to?
the wall?
I guess that would work, but buying the additional sq footage of tile waiting to change the bathroom years down the road is a waste IMHO.
But then again, it will be easier to lay with less cuts...
either or I guess
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 06-21-2005, 01:29 PM   #4
Construction Junkie
Good advice from both. Thanks. I'm going to take the middle road- avoid extra cuts by just laying tile up through the bottom of the vanity and under the sides also so it's nice and stable and looks like it goes all the way through. The vanity (of course) is bolted to the wall studs. Thanks again.
the wall?
either or I guess
Old 06-21-2005, 01:47 PM   #5
Contractor
I don't like the idea of a vanity sitting in a hole created by tile. It makes too good of a place for standing water to go. You will always get water in a kitchen or bath.
Teetorbilt is offline   Reply With Quote
Old 06-21-2005, 01:57 PM   #6
Construction Junkie
Thanks for the wise words, all well considered. The cost of tile is negligible compared to the peace of mind bestowed by a watertight floor. I'll tile all the way through.
Old 06-21-2005, 09:34 PM   #7
Contractor
If the cabintry is particle board, as most are, seal the bottom edges with old varnish or some other sealer. Glue plastic strips to the undersides before installing. These steps will really save you when the flood comes.
Old 06-23-2005, 06:14 PM   #8
I agree, the same should be done for toilets. Tile around the flange and then set the toilet. Like previously stated if you ever wanted to change your'e fixtures you wont have to deal with tile that may have been discontinued.
plumguy is offline   Reply With Quote
Old 06-23-2005, 06:42 PM   #9
Construction Junkie
Thanks, all- the shower is framed, pan is in, all will be mudded tomorrow and next day, I think, then I'll tile that floor. Then plumbing, vanity, sinks, toilet, fixtures, tiling shower. I'm going to do a cool hand plaster job on the walls. ..gosh, I just love this.
Old 06-23-2005, 10:10 PM   #10
Construction Junkie
What kind of plastic strips? I've never heard of such a thing but you're the pro and I want to do it right. Thanks.
Old 06-23-2005, 11:17 PM   #11
Contractor
I used to use the tap-in plastic furiture glides and shim the cabinets with the plastic wedges used for toilets. I now use plastic vertical blinds ripped through a tablesaw. Anything that won't wick water to keep the cabinets up and out of the water.
You have to expect the worst but even just mopping can introduce a certain amount of water to the cabinets where they contact the floor.
Old 06-24-2005, 06:55 AM   #12
Hey Teetor, that is a great idea. I can't tell you how many bathrooms I've been into where there is water damage on the side of the vanities.Now what do you do with the small gap that has been created? Do you leave it open or maybe seal it with some clear silicone?It's funny here in MA it is plumbing code to seal the base of a toilet where it meets the floor. I have never seen it enforced it usually comes down cosmetics. Most people like that free standing look... kinda like a pedestal leg. I've pulled many a toilet and seen some really bad conditions! At least today you don't see a lot of heavy mopping with new products like swifter.
Thanks for the new idea,
John
Old 06-27-2005, 10:00 PM   #13
Construction Junkie
Lightbulb
In my house there's a lot of mopping and I don't use Swiffer mops because it steams me to be throwing away a mophead. So, do you seal the gap with caulk?
By the way, in case you're ever asked, the best mop on the planet is the Bissell Steam Mop. Cleanest clean you ever saw, no chemicals-water only, so no residue of any kind, and the mophead's washable. I'd pay any price for this product but it's only about $70. If you have a big house (I do) buy several mopheads.
Old 06-27-2005, 10:22 PM   #14
It is hard to argue against applying a small bead of caulk around the base of the toilet and vanity. There are so many colors of tile,grout, fixtures that trying to find caulking to match might be difficult. Clear caulk is always a safe bet.
I've never heard of anyone getting "steamed" over the swifter and resolving it by purchasing a "steamer". Thanks for the info I've heard the new steamers are great for all around cleaning and when you leave the house you should be wrinkle-free!!
Old 06-28-2005, 03:40 AM   #15
I caulk around all tubs, showers, toilets, and vanities in bathrooms that I remod.
Especially around toilets. If they leak, it keeps the water contained to the toilet area.
I always seal the bottom of vanities or any wooden structure that meets the floor with polyurethane (3 coats for assurance.)
CarpenterDon is offline   Reply With Quote
More On This Topic
We finished our drywall. We put our first coat on yesterday, of drywall mud to seal up all the joints and the nail holes. This morning I came in and finished the top layer of the drywall. I used a twelve in knife which makes a nice wide band here, makes... Read More »
Anyone in real estate will tell you that money invested in the construction or remodeling of a bathroom will be money in your pocket when it comes time to sell the house. There are lots of choices to make and choosing the right bathroom vanity can make... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
How to Remove a Toilet
How to Remove a Toilet by Expert Village
Today we’re replacing a dead toilet, one that leaks real bad. What we’re going to do is after you clean the area and get everything all prepped, you’re going to disconnect the water supply. We already have the water turned off. You just... Read More »
Chemical toilets are located in areas such as airplanes, recreational vehicles and boats. They also offer a sanitary solution when a conventional toilet is not practical. There are a few guidelines to follow when you decide to use a chemical toilet to... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
