Closing Off Underside Of Stairs - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 11:14 AM   #1
Closing off underside of Stairs
Im currently working on finishing off my basement. I have a 2 story house, and the stairs to the 2nd floor are over the stairs that go to the basement. You can see the underside of the stairs when going down to the basement, and I'd like to cover them with either drywall or a hardwood plywood.
I'm not sure what would be the best way to do this. The finished product will be painted, Im thinking the hardwood plywood would be the best way to go.
Any thoughts?
robb01 is offline   Reply With Quote
Old 04-28-2011, 01:16 PM   #2
Rewards Points: 2,238
Hi!
Welcome to "DIY"!
5/8 's inch, Type "X", firecode drywall, on the underside of the stairs - for
starters.
Post some pictures!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-28-2011, 01:21 PM   #3
Also, since you're going to finish your basement off -
see this useful link (from a member here) - concerning "Fire-Stopping" -
How to fireblock framing
Very good read!
rossfingal
Old 04-28-2011, 01:22 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I don't know your experience level, and I'm not sure this answers your question, but you might take a look at this thread:
It's a good thread, but long. Page 5 goes into stairs too.
Edited to add: Oops, just a little too slow.
The Following User Says Thank You to Blondesense For This Useful Post:
rossfingal (04-28-2011)
Old 04-28-2011, 04:06 PM   #5
Im more worried about aesthetics. There is currently no "fire block" now, so Im just wanting something that will look nicer than what is currently there
Old 04-28-2011, 04:42 PM   #6
If you're going to cover the underside of the stairs - something that complies
to "Fire-code" is a must!
"Fire-code" isn't "aesthetics" - it's "Life Safety"!
If you cover the underside of the stairs with something that is not fire-
code compliant - Oh, well - not my stairs!
You can always put the drywall on first, and then the wood -
(NO, 1/2 inch drywall is not compliant!).
You came for advice - I hope you listen.
By the way, one of my "specialties" as a Philosophy Major in college was
"Aesthetics" - it's good to talk aesthetics, once in a while!
Regards, in your quest for beauty!
rossfingal
Old 04-29-2011, 10:40 PM   #7
Registered User
Rewards Points: 5,266
What a coinkydink.... I just posted this last, about 10 min. ago.... R302.7 Under-stair protection. Enclosed accessible space under stairs shall have walls, under-stair surface and any soffits protected on the enclosed side with 1⁄2-inch (12.7 mm) gypsum board. http://publicecodes.citation.com/ico...002_par018.htm
Gary
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 4 12-01-2011 06:55 PM
drywalling underside of kite stairs dano10 Drywall & Plaster 1 12-27-2010 05:12 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
closing in porch stairs - design question wombosi Carpentry 3 10-12-2008 11:18 PM
