Closing Off A Room - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 08:26 PM   #1
Closing off a room
I am looking to close off the wall where the opening in the picture linked below is. As you can see I have hardwood in both rooms. I presume I should take the hardwood out beneath where the wall will be framed. Any suggestions on how to do this easily without damaging the hardwood remaining in either room. Also, how much of a gap do I need to leave between the remaining hardwood and the bottom plate?
(Sorry I can't post attachments so I put the photo up on my website)
http://www.williamsworx.com/IMGP1135.JPG
former33t is offline   Reply With Quote
Old 12-09-2008, 09:10 PM   #2
Rewards Points: 162
Is the hardwood floor a true solid wood hardwood floor, or is it a composite type product? If it is a solid wood floor, I would leave it in place and build your wall over top of it. If you ever decide to add carpet in the future, you would carpet right over the top.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 12-10-2008, 01:56 PM   #3
Drywall contractor
Rewards Points: 1,070
I'd leave it too if it's actual wood. Put the bottom plate down with screws. If someone later wants the opening back, just fill the holes, touch up the finish and the floor is good to go.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-11-2008, 06:35 PM   #4
Thanks for the advice. The wood is real genuine hardwood. The advice makes sense, so I'll go with that.
run gas line in room on slab stanen8871 Plumbing 8 12-01-2008 11:15 PM
Increase duct size to cool room? tchristian HVAC 14 09-30-2008 03:33 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 09:53 PM
