Closet Vs Bathroom Extension - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 06:08 PM   #1
Rewards Points: 87
Closet vs bathroom extension
I am planning my master bathroom remodel and I don't know whether I should transform it to (option 2) Bigger bathroom/no walk-in closet or (option 1A & 1B) L-shaped bathroom/ small walk-in closet?
I tend to like (option 2) however we'll lose a walk-in closet and we'll have to build a closet (what size?) using the space in the small master bedroom (12'x15.5').
Option 1A keeps the access to closet in the bathroom (moisture problem?)
Option 1B builds a new doorway accessed from the bedroom?
What do you think?
Last edited by Stephen S.; 03-18-2010 at 06:37 PM. Reason: add door to new closet in option 2
Stephen S. is offline   Reply With Quote
Old 03-18-2010, 06:23 PM   #2
Where is the door to the closet shown in the bedroom ?
I'd keep a closet, but might look weird with 2 doors in a row (1B)
Old 03-18-2010, 06:40 PM   #3
Rewards Points: 87
Doorway added in option 2 ...
Old 03-18-2010, 07:11 PM   #4
I think I'd go with 1a then = closet access from the bathroom
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Stephen S. (03-19-2010)
Old 03-19-2010, 08:54 PM   #5
Rewards Points: 87
Anyone else has more suggestions ?
A picture is worth a thousand words.
Old 03-20-2010, 12:00 PM   #6
Rewards Points: 252
I think I also would go for option 1A. I like the openess of option 2, but wouldn't want you taking space from the bedroom for a replacement closet. Also, it's nice to have closet access directly from the bath area for "her" closet...
Itsdanf is offline   Reply With Quote
Old 03-20-2010, 06:59 PM   #7
Rewards Points: 87
Seems like 1A is the way to go. My wife also doesn't like the idea of taking up space from the bedroom. Good for me as 1A has the least amount of work involve among all
Will there be any potential moisture problem by putting the closet inside the bathroom? I'll vent the bathroom to the outdoor, it's currently into the attic (what fan size do I need for the bathroom + closet size = 100sq ft.?)
Thank you.
Old 03-20-2010, 07:14 PM   #8
Rewards Points: 252
Thank you.
Keeping the wife happy with the easiest option: Priceless!
Shouldn't be any moisture problems with the closet as long as the door's closed when generating humidity. I can't advise on fan size (although 100sf is not a huge bathroom; don't think there's much risk that you'll be undersized).
Old 03-20-2010, 07:20 PM   #9
Seems they recommend bathrooms have 8 ACH (air exchanges per hour)
So 100 x8 = 800 /8 = Min 100 cfm
Anything rated 100 or over would be good
We don't use our fan in the winter, we need the humidity in the house
We have a small bathroom & our fan is rated at over 100 I think
Old 03-20-2010, 07:33 PM   #10
Rewards Points: 252
By the way, I think the final bathroom layout with option 1A will be 70sf. No need to include the closet in the estimate for fan consideration...
Old 03-20-2010, 09:05 PM   #11
Rewards Points: 87
Great, so 100cfm fan is more than enough to do the work Thank you guys !
More questions
1) What do you guys think of putting a new window at the wall above the bath tub (will be a soaking tub), I saw posts that putting windows in bathroom is looking for trouble but above a soaking tub without much splash should be less problematic?
2) Windows size suggestion? 5 wide wall I saw from a diy site that I don't need to make temp support wall if I cut only one wall joist while framing, is that true? The exterior tub wall is a supporting wall with roof truss system on top.
3) Here's a picture of the wall (made of 2x4's), with fiberglass insulation (r11) + cuts made on the paper facing interior while I removed the fiberglass shower. Any way to add more insulation by replacing with something else? If I don't need to replace the insulation, should I fix the cuts by taping or add a poly to cover the whole wall ?
4) Any good soaking tub suggestions?
5) My plan is to do a Kerdi shower system + Ditra floor (waterproof!) and I'll use Denshield as the backerboard for new shower wall (Double protection? Redundant?) Can I thinset the Kerdi above painted/textured walls?
Old 03-20-2010, 10:01 PM   #12
I don't see a problem with a window above a bathtub
Problems arise with windows in a shower subjected to water over time
R15 will fit in a 2x4 wall
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Install of Closet Flange Extension Kit commanche20 Plumbing 2 11-17-2009 09:35 AM
Bathroom sink drain extension Docfletcher Plumbing 2 12-10-2008 10:30 AM
new bathroom water closet TonyD Plumbing 1 03-11-2008 10:27 PM
Installing a stackable washer dryer in hall closet next to bathroom uncleb23 Plumbing 2 10-04-2007 07:51 AM
