Closet Size Help... - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 12:27 PM   #1
Rewards Points: 150
Closet Size Help...
I am building a master bedroom closet, and need help with the right size and doors. I would really prefer to put standard doors on the closet, but am not sure if they will be wide enough.
The closet's will be 12' long by 26" deep (reach in closet). I was thinking of doing 2 with a door for each. That means, each closet will be 6' by 26".
With that size, am I stuck doing bifold or sliding door's for access? What would be the max I can go, and put a standard 30" or 36" door on it?
dcd22 is offline   Reply With Quote
Old 09-21-2009, 01:02 PM   #2
Remodeler
KlintP's Avatar
I have a 6 foot closet in a secondary bedroom with a 30 inch door. I don't remember the depth off hand. You may have trouble easily reaching items on either extreme side of the closet. Can the closet be any deeper? That would also help access and visibility of the clothes.
KlintP is offline   Reply With Quote
Old 09-21-2009, 02:34 PM   #3
Rewards Points: 352
It's a pretty shallow closet so maybe you could do the two closets with two sets of double doors. Two 24" doors (open from the middle like french doors) would give you good access and would not swing to far into the room. A top and bottom catch/latch would give you 48" of access to each closet.
Rege
RegeSullivan is offline   Reply With Quote
Old 09-27-2009, 08:54 PM   #4
Remodeler
KlintP's Avatar
I measured my secondary closets. They are actually closer to 7 ft wide with a 30" door. And are 23" deep.
I think I would go with sliding doors if I was you. Since it's the master closet and you probably need every bit of the space easily reachable.
I've seen some really attractive sliding doors that look stylish.
Linen Closet Lighting stubits Electrical 24 06-19-2009 11:32 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
