Closet Opening - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 12:03 PM   #1
Closet Opening
I wanted to increase the opening of my closet so I could use the space better. I did some reading because I wasn't sure if it was a load bearing wall. I live in a cape cod built in 1940. The closet opening is in a wall that runs parallel to the roof and floor joists below. I realize I'm dealing with "generalizations" and many sites just tell you to contact an engineer. I thought that if I removed the drywall/plaster, I would have a better idea. When I did this, it looks as if there's a header, but it looks like they used it for hanging a sliding closet door because of the two little pieces of hardware stuck in between.
I guess I'm just looking for reassurance that I can remove the center stud. Any advice or suggestions?
rockbb is offline   Reply With Quote
Old 04-08-2011, 01:50 PM   #2
Rewards Points: 5,334
If the ceilng joists are resting on this wall, it's probably load bearing. If not, it's not load bearing.
In either case you can remove the stud. What you did would be based on the load.
Ron
Old 04-11-2011, 07:36 PM   #3
Handyman
Rewards Points: 512
Since you say the ceiling joists run parallel to the header and I see a single 2x4 jack stud I would assume this is not a load bearing wall. However, like the others say, contact an engineer for your own safety
canadaclub is offline   Reply With Quote
Wrapping closet door opening with drywall mfc133 Drywall & Plaster 7 02-20-2011 03:48 PM
Short Closet opening jerome8283 Building & Construction 3 11-25-2009 11:53 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Closet Opening remodel-virgin Carpentry 2 06-13-2009 08:29 AM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
