Closet Door Height? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 06:22 PM   #1
Rewards Points: 97
closet door height?
My opening for the closet door is 78" high. It is all finished. I have wood floors. What height do i need to cut the closet to? I'm thinking 76"? One inch gap at top and bottom? Anyone?
bcbud3 is offline   Reply With Quote
Old 04-18-2013, 06:32 PM   #2
When you say ," cut the closet " , do you mean the closet door ? If so , you should look at the instructions for the door hardware .
Az Framer is offline   Reply With Quote
Old 04-18-2013, 07:34 PM   #3
Rewards Points: 85
So far as the bottom goes it should be 5/8" from bottom of door to your finished floor. This would be for venting. 1" on bottom would stick out like a "sore thumb."
Just my two cents, rredogg
rredogg is offline   Reply With Quote
Old 04-18-2013, 08:23 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
most closet doors are the same height as any other door unless their bifolds.
1/2" gap is fine for under teh door. 1/8 at teh top of the door
woodworkbykirk is offline   Reply With Quote
Old 04-18-2013, 09:08 PM   #5
Rewards Points: 97
sorry, it is a bifold closet door
Old 04-18-2013, 09:11 PM   #6
DIY staff
Rewards Points: 7,174
Install the top track and then measure----I never trust the instructions completely---top track and clearance is likely 3/4 inch, but use a ruler and verify for yourself.
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 12:14 AM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 02:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
