Clogged Drain Line - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 07:19 PM   #1
Clogged Drain line
I just bought a house that was flipped by a contrctor that knew little to nothing on fixing up a home. that being said:
I have a clogged sewer line from the master toilet. I have tried a commercal grade cleaner, no result! I have snaked the drain up to the clog but after a number of tries the snake will not penatrate through the clog. I believe the clog is below the junction where the sink ties in. I think this because if you run the sink for a period of time, water backs up in the toilet.
I see under the house, on the drain line there is a cap that I can unscrew so I can access the line. By doing this I believe I can remove the clog or snake. Is the sewer line filled with water or is it dry? Is unscrewing the cap an OK idea. Also a side note the lines are cast iron, which I know clog eaiser. Any suggestions/help is welcome
Thanks for those reply
Ruski is offline   Reply With Quote
Old 06-24-2009, 06:25 AM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
That cap is your cleanout. There may be a bit of water in it, but it sounds like the water is getting some passage, so if you wait a few hours after running any water you should be able to unscrew it with little water coming out (hopefully not much of anything else coming out!) Maybe have a bucket handy to catch the drainage so that you dont have to be near it while snaking the rest of the drain line.
Man of many hats
wrangler is offline   Reply With Quote
Old 06-24-2009, 07:29 AM   #3
Joe F's Avatar
Rewards Points: 294
I think most rental centers will rent a powered snake. Might be worth loogking in to if your going to open a main clean out.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 06:11 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
