Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-24-2009, 11:54 AM   #1
Cleaning grout off tile
I just finished a shower stall project (this is before I grouted) :
My question is this, I got grout all over the tiles, and while most of it scrubbed off, some almost looks like it stained the tile. It's a very thin coating that I can feel with a fingernail in some spots and in others it's down in the texture of the tile.. Is there a good way to remove this excess grout that wont damage the tiles?
wineslob is offline   Reply With Quote
Old 04-24-2009, 08:42 PM   #2
Is that grout or thinset? Either way the longer it stays on the more difficult it will be to remove. A scouring pad and water would be your best bet. Acid washes are available, although they can stain your tile. The tile or stone that you have used appears to have a matte finsh, which of course will make this job more difficult. In the future clean the tiles before the thinset dries. In some cases a grout release should be applied to the surface (not the edges) before grouting. Check with the manufactor.
Mop in Hand is offline   Reply With Quote
Old 04-25-2009, 08:21 AM   #3
Scrubby pad, thinset will come right off, next time use a sponge and water as you go, you won't have this issue.
R&D Tile is offline   Reply With Quote
Old 04-27-2009, 01:07 PM   #4
Thanks for the reply(s).
I got it all off using (major embarrassment here) a product that is made where I work! I diden't know that it would work on tile (we make it for cleaning masonry) so I wrote it off. It turns out that as long as there's limestone in the product it'll attack it.
The stall looks fantastic now.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
cleaning off grout roost Flooring 12 03-19-2009 10:15 PM
cleaning tile grout mguillen Flooring 6 03-19-2009 10:13 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
