Cinderblock framing & insulation
I'm currently in the process of a remodel by turning a 425sqft cinder block shop into a family room. I'm planning on building 2x4 walls on the interior and then insulating with R13 faced fiberglass and then drywall. The shop sits on a slab so I'm gonna use pressure treated 2x4s for the bottom plate and then Douglas fir for everything else.
Some questions I have are:
- Do I need to separate the cinder block from the studs with a vapor barrier?
- Should I attach the studs to the cinder block at all or leave a small gap between?
- Should I fix the bottom plate to the slab so it doesn't move at all and then install studs - or - Have a floating wall attached to the bottom plate?
- And lastly the same question above but for the ceiling. attach so wall is rigid or allow wall to float up and down?
Thanks for the help
-Jeremy
