Cinder Block Wall Hangings - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-03-2008, 07:13 PM   #1
Cinder block wall hangings
I'm trying to remodel a basement that has cinder block walls into a salon. She wants to hang large, heavy (75lbs. +) mirrors and shelves from the walls. Are there cinder block wall anchors that will bear this kind of weight or will the block be destroyed?
shnfldr is offline   Reply With Quote
Old 06-04-2008, 07:47 AM   #2
Registered User
Termite's Avatar
There are a multitude of options.
I'd start with Tapcon screws. Be sure to use the recommended size of drill bit, as going too small or too large will render them less effective.
Old 06-07-2008, 08:26 AM   #3
I use a small hammer drill and a masonry bit for drilling this type of hole and many times drill into the mortar between the cinder blocks.
Even if I have to drill directly into the block ,there is always a clean hole with no destruction. I use a sharp masonry bit of the size that is specified on the package of fastener and apply smooth even pressure on the drill. Even though the dust is minor, I wear a dust mask and safety glasses.
Handyman Jim Noonan is offline   Reply With Quote
Cinder Block retaining wall kspencer General DIY Discussions 4 04-20-2008 05:33 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Cinder block wall 3DPiper Building & Construction 1 03-28-2007 11:32 AM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 09:34 PM
