Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-19-2009, 04:04 PM   #1
Question
cinder block and dirt foundations
I have a house that's built on a very tall cinder block foundation. It's got fill dirt inside it. Is it possible to remove this fill dirt and build a room? Would removing the dirt affect the foundation structurally? What about cement footer? should they remain covered with dirt?
gatojojo is offline   Reply With Quote
Old 06-20-2009, 07:35 AM   #2
Maybe. The dirt inside helps support lateral movement of the wall. If you dig it out, you may have to add supporting buttresses. You can't dig below the footings without additional support. And the final ceiling height needs to be at least 7'6 for a living space, but lower is OK for storage.
Tags
basement remodeling
