Changing Inswing Direction Of An Interior Door - How? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 08:16 AM   #1
Changing Inswing Direction of an interior Door - How?
I have a bedroom door that opens to the inside. Problem is it hits furniture. How do it change it to open into the hallway instead of the bedroom? Thanks!
christie5683 is offline   Reply With Quote
Old 10-07-2012, 08:38 AM   #2
DIY staff
Rewards Points: 7,174
There are two ways---If you want the hinges on the same side---you will need to recut the hinges into the jamb on that side of the casing--after you remove the stop trim---Then re cut the hinges on the door--
Simpler ,if you want the hinges on the other side--would be to remove the casing (mitered trim)---cut the nails holding the jambs into the wall--and remove and reinstall the thing facing the hall---
If the door is nothing special--it would be easiest to simply buy a new prehung door and install that---
Old 10-07-2012, 10:05 AM   #3
Door
Thank you very much. I thought maybe I would have to change the entire door casing.
Old 10-07-2012, 11:40 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
mikes right, if you simply redo the hinges you wont have to touch the casing. when it comes time to patch the old hinges i recommend doing whats called a "dutchman patch" simply chisel the old hinge gains a little deeper 1/4" works then gets some 1/4" stock and cut it to fit the mortise. glue and nail it in place then fill the perimeter with drydex or another type of sandable filler. doing it this way makes for less chance of shrinking and is less noticable when fresh paint is applied
woodworkbykirk is offline   Reply With Quote
Old 10-07-2012, 02:39 PM   #5
WONDERFUL!!!! THANKS. I think I can handle that
Laminate Flooring Direction canadiandude Flooring 4 03-03-2012 04:19 PM
Changing Roof Type Iconoclast Building & Construction 13 07-29-2011 11:15 AM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General DIY Discussions 11 01-07-2011 05:43 PM
direction of laminate flooring reds_21 Flooring 1 11-12-2009 07:48 PM
Carpet on Stairs, Hallway: Nap Direction Carol Emmarie Flooring 5 03-26-2009 11:40 AM
