Certainteed Products Anygood? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-25-2008, 07:08 AM   #1
certainteed products anygood?
I have a bid by a local contractor to reside my whole house. I know he does good work. His bid calls to use Wolverine American legend by certainteed. I am not sure about this product. A few of the other bids include a product by reynolds and comparing them the the wolvering thickness is .042 and the reynolds is .044 which one should I use the rynolds bids are much more but those bids want to use foam board or backer board.
thanks
hobbyguy2002 is offline   Reply With Quote
Old 01-25-2008, 07:56 AM   #2
What is the warranty on these two products?
redline is offline   Reply With Quote
Old 01-25-2008, 08:56 AM   #3
Off the top of my head both are 5 years everything and than of course pro-rated "lifetime" of course I am sure both have small print that change the warrenty if the wind blows from the north temp goes over 90 your kid is left handed you know
Old 01-25-2008, 09:53 AM   #4
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Certainteed is good, but the company with the foam/backing board may be the better way to go. .02 is nothing to even consider in the choice.
Kingfisher is offline   Reply With Quote
Old 01-25-2008, 05:06 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Choose the thicker siding. For one, both Reynolds and Certainteed make good products and probably offer comparable warranties, however it doesn't matter how good the warranty is, thinner siding will get wavy. I wouldn't go thinner than .044. Also for hollow core siding, some type of foam backer would be highly recommended-not just for insulation, but for giving the siding a uniform flat surface. I don't know if it is in your budget, but a foam-backed siding (foam is molded to back) would be the best choice.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-05-2008, 09:02 AM   #6
Ok another question. I think remodiling only leads to more question's. This all began as we needed a new roof now with a new roof we are pricing roof both metal and asphalt, siding facia and soffits, and new windows you have to love homeowership. A question on siding is that rynolds crossroads that we have priced is .050 thick and the foam backed is only .044 does it not have to be as thick because of the foam backing? which would be better. the foam backed is only $840 more for the job. should I go with the extra money and get foambacked. the house is only 16 years old so the walls are in decent shape.
Old 02-05-2008, 10:48 AM   #7
PRO Siding Windows Roofs
wolverine is the economy certainteed. Monogram is the only decent certainteed pannel but it sucks to install. Id go for Alcoa carvedwood or quest.
PKHI is offline   Reply With Quote
Old 02-05-2008, 11:39 PM   #8
We use Alside Charter Oak here and its a breeze to install and I think its .044 (?)
I like it.
TD
tdavis is offline   Reply With Quote
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Here Is How Consumer Reports Tests Products Docfletcher Roofing/Siding 13 08-27-2007 06:09 AM
