Ceramic Tile Over Terrazzo Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2014, 09:20 AM   #1
Ceramic Tile over Terrazzo Floor
I would like to install ceramic tile over an old terrazzo floor. Floor is original to house (Florida mid-60s). I understand there are some required preparatory steps needed before applying thinset and tiling but I would like some further input if anyone has first-hand experience. From what I've found there are basically two approaches; grind the terrazzo down, exposing the raw concrete and aggregate or applying a liquid bonding agent to provide a solid bond between mortar and terrazzo. Seems like bonding agent is by far the cheapest route right now; 5 Gal of "Weld-Crete" costs around $100 and according to manufacturer each gallon does 200-300 SF. Anyone have experience using a bonding agent or know of a more cost-effective solution for tiling over terrazzo? Cheers - Z
MeridianBuild is offline   Reply With Quote
Old 05-17-2014, 09:28 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
I think you got it covered. I don't think you would have to take much off if you grind, just any wax or whatever and rough it up a little.
Robpo is offline   Reply With Quote
Tags
agent , bonding , ceramic , terrazzo , tile
Problem with concrete floor prep for ceramic tile install tdon7 Flooring 8 11-30-2011 11:12 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
Ceramic Tile Staining Over Radiant Floor Heating?! rcuerrier Flooring 3 04-25-2010 10:42 AM
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 08:46 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
