Ceramic Tile Over Metal Fireplace - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 04:07 PM   #1
ceramic tile over metal fireplace
can I install ceramic tile directly over a metal fireplace or do a need a backer board?
paular is offline   Reply With Quote
Old 11-30-2010, 05:40 AM   #2
firestarter
on most fireplaces you can and have to leave at least a jalf inch reveal but every f.p. is different you should refer to owners manual.
firestarter is offline   Reply With Quote
Old 11-30-2010, 05:41 AM   #3
firestarter
every f.p. is different due to manufacturer you should refer to your owners manual.
Old 11-30-2010, 02:14 PM   #4
I suggest using backerboard, even if only 1/4" thick. The metal will expand and contract with the temperature changes. The fatigue on the mastic or any other material could cause failure in that bond, not to mention the integrity of the grout joints.
Schluter (http://www.schluter.co.uk/floor_trim_profiles.aspx) makes square edging in various sizes and finishes. Get the edging wide enough to hid the backer and the tile, typically 3/4" or 7/8" depending on the tile. Use mastic or another adhesive and screw the backerboard to the face of the fireplace (yes, I know it's tin, so use sheet metal screws). Adjust your trim for square and stick your tile to the backer.
Since the masonry backerboard is less a concern for expansion and contraction, your tile will stay fastened to that. If the adhesive you use to stick the backerboard to the surround fails, the screws will keep the backer in place, thus ensuring a long life for your tile.
If you're using marble or granite slabs, disregard what I just said and use clear silicone to glue them in place....
My $.02 for what its worth...
GB Greg is offline   Reply With Quote
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 10:09 AM
ceramic tile transition to laminate Kman92592 General DIY Discussions 1 07-01-2010 09:55 PM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 08:11 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
