Ceramic Tile On A Kitchen Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-18-2008, 06:03 AM   #1
I am new at using ceramic tile. I purchased enough tile to cover one of my kitchen walls. It was recommended to me to use liquid nail to speed up the process of hanging the tiles. Will this work?
BustedBungalow is offline   Reply With Quote
Old 09-18-2008, 06:53 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
It might, Hell if your going to use that why not try the sticky putty that been on T.V.. Only kidding.
No! I would not recommend it. For a kitchen I would use ceramic wall tile mastic. Or better yet, Thin set. Kitchens I use mastic. bathrooms I stay with the thinset. There really isn't much moisture going to effect the tile in the kitchen,That's why I use the mastic. either one would be fine. BOB
Old 09-18-2008, 08:20 AM   #3
kit tile
I would not use liquid nails// thin set is the way to go, probably just as easy...
Neil Munro
Munro Products
revere22 is offline   Reply With Quote
Old 09-18-2008, 08:28 AM   #4
the Musigician
DangerMouse's Avatar
but.... is there any reason why he SHOULDN'T use liquid nails? none given so far......
DM
Old 09-18-2008, 09:09 AM   #5
Registered User
Termite's Avatar
Sure, but are you serious Mouse? It isn't a tile adhesive. It is a multipurpose construction adhesive, but its uses by those wishing to do a professional job are very limited. It is great for some things, but is not the best material, so nobody in their right mind is going to recommend its use in this application.
Old 09-18-2008, 09:30 AM   #6
the Musigician
yup, serious... i have a tube in front of me and all it says is "not recommended for ABS tub surround or polystyrene"
soooo, still no reason given. just curious why someone would recommend it to him?
DM
Old 09-18-2008, 10:25 AM   #7
Registered User
Termite's Avatar
Because they have no idea what they're talking about. That's why.
I agree that it will probably work. But it is not considered an accepted method of doing tile installations in the construction industry. Tile mastic would be much more appropriate, cheaper, and just as easy.
Old 09-18-2008, 10:38 AM   #8
the Musigician
ok, just wondered because i saw a contractor doing the exact same thing to install tile to a wall behind a stove. (grease splatter)
i saw no reason why he wouldn't use it is all. seems to me squeezing a tube is easier than mixing up the stuff.
DM
Old 09-18-2008, 08:29 PM   #9
buletbob's Avatar
DM
Sounds as tho that contractor needed to make a repair and that's what he must of had handy at the time. AS in handyman,Electrician or Plumber, As KC stated no professional would even think of using it.
Old 09-19-2008, 08:11 AM   #10
the Musigician
all good answers, but.... no-one has said why NOT to use it. any good reason other than professional ego? and it wasn't a repair, he glued them ALL with the stuff, then grouted.
DM
Old 09-19-2008, 09:46 AM   #11
Mouse,
Other than better products available for the application:
Liquid nail takes time to set. In this type of application (Ceramic wall tile)
it is very possible for the Liquid nail to stretch then dry leaving the tiles out of smooth wall plane.
When using Liquid nail it is best to mechanically secure the materials together...at least until the adhesive has set.
I hope this helps.
Big Bob is offline   Reply With Quote
Old 09-19-2008, 09:57 AM   #12
the Musigician
mornin' BB!
C|_|
good answer then!, but have some coffee, that wasn't funny or cute at all. Po)
DM
Old 09-19-2008, 10:04 AM   #13
the Musigician
but.... now that i think about it, he didn't brace them in any way, just gooped 'em and stuck them to the wall. maybe he used a faster drying goop? hmmmmm....soopergoop?
DM
Old 09-19-2008, 02:26 PM   #14
Mouse,
You didn't watch the guy close enough.... when ever you turned your back he spit on the back of the tile to make it hold better...
this is an old tile layers trick...works better when you chew tobacco.
If you run out of spit...boogers work good too....
Old 09-19-2008, 02:45 PM   #15
the Musigician
that's RIGHT! i DID see him picking his nose alot... musta had bondo-boogers!
DM
Need Pro Ceramic Tile Advice Sasha2000 Building & Construction 7 10-10-2008 07:49 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 11:26 PM
Kitchen Exhaust Fan in 12" wall? fw2007 Carpentry 3 03-11-2008 05:12 PM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 01:01 AM
