Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-02-2011, 09:52 AM   #1
Ceramic tile bathtub surround
Hi! My bathroom walls are tiled with 3/8" thick ceramic wall tile. I plan on replacing the 3 walls surrounding the tub (shower area) with 1/4" thick tiles. I want to get the new tiles flush with the older ones. The problem involves the two end walls (approx. 12.5 sq. ft. each). What might be the best way to level end walls with existing walls? Thanks
yewot is offline   Reply With Quote
Old 05-03-2011, 10:28 AM   #2
Please explain the process you'll be using to remove the old tile and it's substrate.
How old is this bathroom?
Post some photos so we can see what you have.
It is sometimes impossible to remove only sections of tile without compromising the wall adjacent to it.
Ron
Old 05-03-2011, 10:39 AM   #3
Ron6519, Thanks for your reply. I am removing the tile from all three walls of bathtub shower surround. The underlying walls are plaster (house built in the 1950's). I am just concerned with the two end walls.
Old 05-03-2011, 11:11 AM   #4
You probably have what is called a mud job. If the tub has a shower incorporated into it, and that shower is original to the house, the walls behind the tiles are concrete. The only time tiles are over plaster is if the homeowner did it.
If the tile you want to remove is in close proximity to the bathtub walls, the job will be almost impossible without damaging the tile you want to keep.
If you can answer the question about the shower and post pictures, I can help.
If not, I can't.
Ron
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 11:09 AM
Replacing a bathtub with an existing tile surround Valera8399 Plumbing 7 08-09-2010 07:45 AM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 09:11 PM
Plastic shower surround on top of tile ok? 1973vw Remodeling 4 04-09-2008 01:22 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
