Cement Board On Top Of Cement Brim In Washroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 11:32 PM   #1
avi
cement board on top of cement brim in washroom
I have old walk in mortar base shower which i am redoing (not removing floor base/tiles) . I am installing cement boards on wall they are resting on top the of the side parameters of walk in shower ( the original cement on the side comes 4-5 " up from the side. Is there a way i can bond cement board with this cement parameter.
Also old wall tiles (which are also removed) were going 1/2 -1/4" inside the base shower. What should i use to fill this gap between cement parameter and the floor tiles .....cement or something else. New tiles are going on rest on top of this .
avi is offline   Reply With Quote
Old 09-07-2011, 06:40 AM   #2
DIY staff
Rewards Points: 7,174
This is not a conventional shower----please post pictures.
Old 09-07-2011, 10:29 AM   #3
avi
I have removed the rest of the wall tiles. On the left side you can see that there is cement wall which is coming up couple of inches from the floor .Cement board is sitting on top of this . Also you can see there's a gap between this cement wall and floor tiles as i have removed the old wall tiles. Need help in figuring what to fill in here and how to water proof the area where cement board meets the parameter walls............Thanks
Old 09-07-2011, 10:54 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is that shower pan made of vinyl or is it lead?
XXX
Old 09-07-2011, 10:56 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't see any cement board.
I don't see any gap.
XXX
Old 09-07-2011, 11:29 AM   #6
avi
Shower pan in made of PVC . The picture is before cement boards were put up (will try loading more ). If you closely look there is gap between the cement wall and the floor tiles (on left side). Question how to waterproof this area ?
Old 09-07-2011, 11:35 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Personally I think you are asking for trouble by not also replacing the receptor in a shower that old but OH WELL.
You can use "lattice" to shim the wall studs outward if necessary then use a water-resistant shower wallboard such as Denshield for the walls. Fortunately the wallboard will lap the pan liner slightly. The wallboard can be set in a heavy bead of 100% silicone applied to the top of the wall remnant material.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (09-08-2011)
Old 09-08-2011, 06:13 PM   #8
DIY staff
Sure looks like a lead liner in the picture----
Check out HYDROBAN by Latacrete---
Are you leaving the old tile on the pan?
Old 09-08-2011, 06:51 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sure does!
Old 09-08-2011, 07:05 PM   #10
DIY staff
Just for fun----scratch that liner back by the nails--use a pocket knife or a sharp screw driver---
If it's lead---they do have a useful life,as the lead will oxidize and eventually fail---that tile looks like the 1960s---made a few ashtrays out of tile like that---Mike---
Cement Board cougar01 Flooring 2 10-29-2010 03:35 PM
Cement board Ron Franck Drywall & Plaster 1 01-16-2010 07:01 PM
Laying cement board oguevarra Flooring 18 12-16-2009 09:21 AM
cement board install billyg Flooring 2 07-10-2009 12:52 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 06:25 PM
