Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-13-2008, 09:41 PM   #1
Cement board and tile over laminate???
I would like to tile my laminate kitchen counters. Can this be done if using cement board anchored with screws? Will I encounter problems later?
williaslw is offline   Reply With Quote
Old 10-14-2008, 07:48 AM   #2
You could, Pros are: save time and a little money.
cons: If substrate for laminate is particle board it will swell when wet.
(this could cause problems you would regret)
You will be creating a non standard nosing size /trim challenge
Big Bob is offline   Reply With Quote
Old 10-14-2008, 08:50 AM   #3
Another DIY Zombie
What if you used Kerdi or Ditra over the counter top? As for the Ditra, that would not be all that different than a typical floor install, except the material under the Ditra would have a laminate rather than wood. Or maybe you remove the layer of laminate. Thinking about how well the "mud" would adhere to laminate......
javan is offline   Reply With Quote
Old 10-17-2008, 08:19 AM   #4
we place expanded wire mesh stapled into the existing c-top,,, think its much better system.
yesitsconcrete is offline   Reply With Quote
laying tile on chip board?? J&K Flooring 14 08-15-2008 11:27 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 05:08 PM
Preping green board for tile? stbo2000 Remodeling 9 02-06-2008 10:40 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
