-   -   Cement board and tile over laminate??? (http://www.diychatroom.com/f15/cement-board-tile-over-laminate-29901/)
williaslw 10-13-2008 08:41 PM
I would like to tile my laminate kitchen counters. Can this be done if using cement board anchored with screws? Will I encounter problems later?:help:
Big Bob 10-14-2008 06:48 AM
You could, Pros are: save time and a little money.
cons: If substrate for laminate is particle board it will swell when wet.
(this could cause problems you would regret)
You will be creating a non standard nosing size /trim challenge
javan 10-14-2008 07:50 AM
What if you used Kerdi or Ditra over the counter top? As for the Ditra, that would not be all that different than a typical floor install, except the material under the Ditra would have a laminate rather than wood. Or maybe you remove the layer of laminate. Thinking about how well the "mud" would adhere to laminate......
yesitsconcrete 10-17-2008 07:19 AM
we place expanded wire mesh stapled into the existing c-top,,, think its much better system.
