Cement Board Or Drywall Or Both - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 10:42 PM   #1
Unhappy
Cement Board or Drywall or Both
I had a contractor move our boiler located inside the house right behind the guest bathroom to the garage. The new space will be converted to a linen closet. The knocked down the old drywall and i'm ready to install new drywall but i'm stuck with the following question. Should i install Cement board and then drywall on top of the cement board? Or should i install mold resistance drywall only or cement board only?
I went down to my local hardware store and they said i need to add some black paper to resist moisture and then the drywall on top. I originally was going to install cement board and then drywall because that is how it was originally set up.
The closet will be behind our guest bathroom so there will be some type of moisture.
Thanks in advance
Calvo is offline   Reply With Quote
Old 03-06-2012, 10:48 PM   #2
Rewards Points: 13,690
Confusing post.
Tile board in any wet area if it gets tiled, IE; shower and tub, green board in the rest of the bathroom.
Never install drywall over tile board, waste of material.
Old 03-06-2012, 10:55 PM   #3
Thank you Joe.
I have the Green board ready I am just not sure if i should install anything before to observe moisture. The closet is right behind the shower. Shower - Wall studs - Closet. Does that make sense?
Old 03-06-2012, 11:01 PM   #4
Attached is a picture for better understand.
Old 03-07-2012, 09:15 AM   #5
Rewards Points: 512
drywall it with mold board.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Calvo (03-07-2012)
Old 03-07-2012, 09:23 AM   #6
I agree it just needs mold resistant or paperless drywall but make sure to also install an access panel behind the control valve for future service.
No tile board or vaper barrier needed.
Lowe and HD have simple to install snap in ones. Make sure to buy the larger one.
Calvo (03-07-2012)
Old 03-07-2012, 11:24 AM   #7
Thank you prince & joe. Will try to add an access panel & stick with mold resistance drywall.
Tags
bathroom , board , cement board , drywall , restroom
Cement board over drywall Spacebear3 Drywall & Plaster 1 08-29-2011 06:49 PM
Assistance with tile layout / transition between cement board and drywall JeffreyMCooper Tiling, ceramics, marble 4 08-20-2011 11:47 AM
drywall compared to cement board on garage ceiling Goob Drywall & Plaster 4 04-05-2011 03:57 PM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 02:31 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
