Cement Board - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 04:41 PM   #1
Rewards Points: 87
Cement Board
I am finishing a wall behind a wood stove with rock wool, steel framing and tile so it will be insulated and completely non combustible.
1. What is the best way to the cut cement board?
2. What is the best way to fasten the cement board to the steel studs?
3. What should my nail/screw pattern be for the cement board?
Thanks!
hellonoko is offline   Reply With Quote
Old 09-06-2013, 01:42 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Depends on the board. Some can be scored and snapped.
I prefer use a hardi blade in my circ saw. Make
sure you use a mask and cut upwind.
As for screws check the board manufacturers web site
for their recommendation. Drywalls screws won't work.
Cement board screws might, but that will depend on the
thickness of your steel studs. Heavier gauge is better.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
hellonoko (09-06-2013)
Old 09-06-2013, 04:04 PM   #3
DIY staff
Rewards Points: 7,174
Durrock and wonder board can be scored and snapped like drywall---or cut with a diamond blade on a grinder or wet cutting circular saw--I slap a wet sponge against the blade and dust becomes mud instead.
Hardie needs a V shaped carbide scorer---and is snapped by bending it upward on the side of the score---diamond cutter as above.
You can cut curves with a jig saw and a carbide blade on either product.
Old 09-06-2013, 05:23 PM   #4
Rewards Points: 454
They have a hardi board type now that cuts like drywall.Regular durrock is a pain it dont cut smooth with a knife and useing a powersaw the dust is brutal.There is a durrock screw that you shoud use but iam not sure you can get the cutter type to go thru them metal studs so you may have to pre drill..As far as the screw pattern,the board i have seen has dots on it showing you where to put the screws.
scottktmrider is offline   Reply With Quote
Old 09-06-2013, 05:36 PM   #5
Rewards Points: 13,446
Could have just used 5/8 fire rock and be a whole lot easier. And no dust to deal with.
12penny (09-06-2013)
Old 09-06-2013, 06:37 PM   #6
Rewards Points: 87
@joecaption is fire rock fire rated drywall? what is a brand so I can look at a MDS sheet.
Old 09-06-2013, 06:48 PM   #7
Here's just one of the many products.
http://www.nationalgypsum.com/produc...ProductID=2346
Old 09-06-2013, 06:58 PM   #8
Rewards Points: 87
@joecaption - Thanks but isn't cement board a better backer for the tile I plan to put behind the wood stove since it is super rigid?
Old 09-06-2013, 07:29 PM   #9
DIY staff
Cement boars is not 'super rigid'----rather floppy actually---but just fine for wall tile----and a good choice for the area behind a stove.
Old 09-06-2013, 07:45 PM   #10
Rewards Points: 87
@oh'mike - cement board is more rigid and durable than sheetrock though?
Old 09-06-2013, 07:59 PM   #11
You never mentioned you where installing tile.
Old 09-06-2013, 08:10 PM   #12
Rewards Points: 454
He said rok wool,steel framing and tile.Thats why i said use hardi backing sheets and be done with it.Alot eaiser to cut than durock.
Old 09-06-2013, 09:15 PM   #13
DIY staff
Hardie backer is stiffer than drywall---Durrock is not---but either one will do what you want.
A note on wood stoves---they will get the wall really hot if you install the stove closer than the recommended distance.--
If that is your intention---add a heat diverter between the stove and the wall---this could be sheet metal--or masonry---
I heat with a wood stove---
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 04:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 06:17 AM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
