The Background
I want to eventually sell my very small house. That will require me doing something to add bedrooms in the basement because upstairs renovations have left me with only one.
I've re-graded the lot, installed extra long down spouts, trenched the basement interior perimeter. laid down washed rock and weeping tile to a sump, installed heavy poly, had a new cement floor put in, parged interior walls.......and a partridge in a pear tree.
I'm very close - but juuuuuust shy of perfect for a completely moisture free basement. The weak link in the chain..........are the block walls.
No water is present, but there is a vaguely dampish mineral deposit showing up on the floor along the one interior side and a half perimeter.
It does not appear to be dependent on how MUCH it rains......just that it rains. It does not appear to be dependent on the DIRECTION the rain is coming from..........just that it rains.
In this instance - exterior weeping tile is not an option for a variety of reasons that are immaterial to my query.
My Understanding
From everything I've read, rain and ground water will permeate blocks from the outside literally filling up their interior like a bucket and then leaching with time thru the cement/cindercrete.
One Option I Saw
I ALMOST bought material from this place:
http://www.diybasementwaterproofing....baseboard.html
But delayed the purchase because my place was briefly up for sale this past year.
Then after thinking about it for a while, I got concerned that perhaps the small "drain pipes" in the installation might become clogged in short order with (high content) alkali/minerals from the soil making all the work and expense for naught.
In addition, I have already framed, insulated, wired and poly'ed the walls making a pile of work to disassemble and re-do.......I mean I WOULD do the work if this was the right application for the product......then there's the 2" clearance from wall required for the product......hmmmm.......??
My Question
If the block voids are the problem....what about drilling a hole X 2 in each and every block and filling them up with something (remember - this is a tiny house) Putting something like that expandable foam stuff in. Obviously the fear.....no......
terror....... would be putting too much of the stuff in and having a block blow.
I'm actually prepared to buy some blocks and experiment in this regard.
When blocks are cemented, are they not open to each other? If so, that would give some leeway for expansion wouldn't you think?
I'm fresh out of ideas. Any suggestions or comments would be greatly appreciated.....thanks !
